and electrical components to a high standard. Duties included in the Electrical Assembler role: Cable assembly Work from drawings... role: Previous cable assembly, wiring or electrical assembly experience Able to read and follow engineering drawings/work...
drawings and specifications. Assist with cable installation, containment and associated electrical works. Support inspections...MSS Infrastructure are looking for Mechanical and Electrical Apprentices to join major HS2 works across the Midlands...
experience in electrical wiring, fitting or assembly relevant to the role. Ability to interpret and work from engineering... drawings, electrical schematics and technical documentation. Competence in cable preparation, termination and electrical...
and electrical assembly tasks, including soldering, crimping, cable assembly and rack wiring. Use standard electronic measurement... and environmental sciences. About the Role We now have an opportunity for a Senior Vacuum Electrical Technician to provide vacuum...
out the assembly, testing and, where appropriate, the refurbishment of the Company's products. As an Electrical... Assembler will have the following skills; Experienced in Electrical Wiring and Electronic Assembly. Previous experience...
testing, cable assembly, or similar workshop-based electrical work. Recently qualified electrical apprentices, electrical... Carrying out electrical testing Replacing cable ends and carrying out minor repairs Repackaging and preparing cables...
controlled electrical and harness documentation in SolidWorks Electrical Create detailed cable assembly drawings including...Electronics CAD Technician / Cable Assembly Draftsman (Permanent) - Autonomous UAV Manufacturer A pioneering UK...
assembly and looming using lacing and other cable accessories Assisting with the wiring of sub-assemblies/enclosures...Our client, a major player in the Defence & Security sector, is seeking an experienced Electrical Technician...
and interpret electrical schematics, wiring diagrams and technical drawings. Strong practical skills in wiring, connectors, cable... assembly and electrical integration. High attention to detail and a quality-focused approach. Experience working...
weekly between: Early Shift: Mornings Late Shift: Afternoons Key Responsibilities Perform electrical assembly, high-voltage...JOB TITLE: Electrical Fitters - Hydrogen Power Generation LOCATION: Newcastle upon Tyne CONTRACT: Full-Time, Contract...
